Microphone problem i really need some help
Posted: Sun Nov 07, 2010 7:56 pm
Hi Guys
Like the tittle says i am having real problems trying to wire up a microphone to a harrier cbx and i really hope someone can help me out.
Ive tried a couple of diagrams and had no luck including the one on this site and im about ready to get a hammer out
http://www.thunderpole.co.uk/mic_wiring.htm
It is a (other company) microphone CM-500U i bought it from maplins http://www.maplin.co.uk/Module.aspx?Mod ... Code=A37GJ
Everything i have tried has not worked on the diagram on this site i get sound but it wont key up and when i do press the ptt button the sound goes but im sure the needle is still responding to the skip on the channel (hope that makes sence)
Strange thing is i get sound and if i pop a metal object across pins 1 and 3 the radio keys up and the metre and swr metre respond.
The colours on the microphone wire are yellow shield black and red if it helps i can put the colors of the wires inside the case and take a picture.
Hope you guys can help many thanks Mike
