SWR Before and afterburner....
Steve
Hi, (Afterburner! . . thought of that all by myself!.... :D )
So anyway, I have my SWR down to just a flicker after the amp (on and off, with slight adjustmet for the xtra power). And still just a flicker between the rig and the amp, with the amp turned off.... But! If I have the SWR meter connected between the rig and the amp, with the amp switched on, my SWR reading shoots up to 3! ....... Is this normal????
TTI-880, Siro 4000, K-PO EA150P.......
Thanks!....Steve.
fit the swr meter between the antenna and rig without the burner in line then you will get a true reading set the antenna the reinsert the burner in place and all will be well withe the world
:D :D :D :D
Steve
Thanks, the SWR reading is fine without the burner so I will just ignore the reading with it in line.
Thanks again Stampman.
Steve.
:D :D :D
no problem thats what we are here for
