more antenna help please
Posted: Tue Mar 08, 2011 10:12 pm
by pyromad
Hi again,
I have just bought myself a mag mount for my car and i wana use a Dial-a-match base loaded antenna that i was given. but the instruction page i have sais this needs to be grounded? how would i go about doing this with the mag mount in the middle of my car roof?
Re: more antenna help please
Posted: Tue Mar 08, 2011 10:19 pm
by snowman
http://www.cosjwt.com/index.php?a=3 (is it ok to put this on andy)
Posted: Tue Mar 08, 2011 10:32 pm
by pyromad
Thank you, that is a very intresting read and was very useful.
Posted: Tue Mar 08, 2011 10:42 pm
by snowman
i have as many others used mag-mounts with great success ( gone on for years) and they are a handy no hole quick fit solution and put a antenna in the best spot in the middle of roof but....... you cant beat a drilled bolted mount for good clean earth and solid prob free mounting!!!!!! still i use a mag on the car and it works well.
Posted: Tue Mar 08, 2011 10:54 pm
by stoner_26
i use a mag mount and even use the rubber protector aswell to protect my paint which give a thicker space betweem mount and metal and i have found it easy to set-up and no problems with ground plane and works fine for me :)
Posted: Tue Mar 08, 2011 11:47 pm
by Dragonfly
Magnetic mounts dont need to ground to the car.
The Dial a Match antenna is a great little antenna and is a doddle to tune as all you do is turn the metal ring up or down the threaded outer base load to tune it .
If the SWR stays way to high then coil inside may have gone short,I have had a couple of these Antennas and they usually only lasted a couple of years before developing a short .
Posted: Wed Mar 09, 2011 12:35 am
by pyromad
Thanks for all the replys i will try and get my anteena set up and working in the morning. I do have another antenna that i was also given but have no instructions with this 1 so dont know the make.
Posted: Wed Mar 09, 2011 8:39 am
all antennas work and swr the same way by either shortening or lengthening the whip
Posted: Wed Apr 20, 2011 8:04 pm
by joe jeep
I use a 6" mag-mount with a rubber boot and a Voyager aerial, get almost perfect ground plane. One question I have is that would the mag mount work as a ground plane on its own, yes it wouldn't be great but would it act as sort of a ground plane.
Posted: Thu Apr 21, 2011 8:19 am
no it has to have a metal area underneath it
