Page 1 of 2
BURNERS
Posted: Wed Jan 10, 2007 3:57 pm
by the messiah
hi, i have heard allot about burners... but... where do you get them from, i cant find any?
Posted: Wed Jan 10, 2007 10:26 pm
by Steve
Hi, I think you will find most CB radio suppliers do sell these things but don't often advertise them. I guess this is because they are illigal for use with CB radios, the max legal output being 4W...... (they are great tho!... get one!!!!.. :twisted: )
:D :D :D :D
Posted: Wed Jan 10, 2007 10:30 pm
by Steve
Forgot to say...Try the phone number on this website first tho! Excelent service and very knowlegable people!....
:D :D :D :D :D
Posted: Fri Jan 12, 2007 2:42 pm
by the messiah
thats fraet thankyou
What Wattage burner
Posted: Fri Feb 09, 2007 9:02 pm
by boyscout
Hi would like to know what size of burner I should buy? Is 35W ok or do I need somthing bigger. Want to boost my range not walk over everyone. One other thing is will the burner help me recieve a better signal? (I don't think it will but asking the question anyway.) :D
Posted: Sat Feb 10, 2007 8:26 am
get 100 watt with preamp built in this will do the job for you
Posted: Sat Feb 10, 2007 10:42 am
by boyscout
:) got any recomendations, can't seem to find any that have a built in pre amp.
Posted: Sat Feb 10, 2007 12:35 pm
ring colin at home site he will sort you out
:D :D :D :D :D
Posted: Sat Feb 10, 2007 5:01 pm
by boyscout
found one on (other company) cb site. It's a RM Mod 160p (KL200p) for £49.95 is that a good price. Does not mater this month as at that price it will have to wait. Already had to pay for the rig this month and money does not grow on trees LOL :shock:
How do you install an burner?
Posted: Wed Feb 14, 2007 9:17 pm
by boyscout
I would like to know how you install an amp? and do you SWR your antenna in first and check the reading is under 1.5 before installing the amp. Or do you SWR the antenna in after the amp is installed. Also do you have to take a direct feed from the 12V battery? :?
Posted: Wed Feb 14, 2007 10:29 pm
setthe swr first aqnd get the reading about 1.5 or very close to connect burner to 12 volt supply and put where thre swr was and yu should be sorted remember burners are not for talking to your mate 2 streets away need to be used at 10+ miles for satisfactory use
Posted: Thu Feb 15, 2007 9:11 am
by boyscout
Why is that stampman? So is it best to get a burner with a on/off switch just in case you get a closer contact? So with a 100 Watt burner what sort of range is it going to push out. Bought the UK CB handbook and it says in open country on a good day the range of a standard 4 Watt set with no burner is upto about 9 miles. I do know that if you double the wattage you don't double the range.
Posted: Thu Feb 15, 2007 9:41 am
your range will varey depending on conditions i have got from lancaster to portsmouth on 4 watts other days im lucky to get 5 miles so a lot depends as i say on conditions if you get the best set up then relax nowing that everything else is dow to the gods and whatever set up the guy/gal has that you are talking to
Posted: Thu Feb 15, 2007 12:19 pm
by boyscout
:D LOL I see that it is all a bit hit and miss. Just have to keep the fingers crossed and hope that there are some breakers out there that want to chat. Funny thing is after reading the CB book it seems that we have been given the pap end of the stick when it comes to the restrictions. 27Mhz sandwiched in between to other bands. and the power and antenna restricted to 1.5m and 4 watts. @ 27Mhz the ground-path attenuation is at its highest. Not that I am complaining as setting up is half the fun. Just a bit put out as Im ex RAF and don't usually have to worry to much about getting a contact on the radio as I know all the kit runs on the better bands. :wink:
Posted: Thu Feb 15, 2007 1:13 pm
go air/mobile problem solved //////
