loft antenna
Posted: Sat Oct 29, 2011 1:32 pm
by needle bender
How well would a siver rod type antenna work slung horizonal in a loft space...any of you antenna buffs got any idea??? :D
Re: loft antenna
Posted: Sat Oct 29, 2011 6:10 pm
by Dragonfly
They work very well , the only drawback is that they are somewhat directional when laid on there side .
Re: loft antenna
Posted: Sat Oct 29, 2011 6:34 pm
range could be a problem as mobile cb antenna are vertical
Re: loft antenna
Posted: Sat Oct 29, 2011 8:27 pm
by Adriano9966
:D what I use on cb is an inverted v loft dipole which has near vertical polarisation so almost like a vertical but with slightly less noise and the advantage that it uses less space each leg(1/4 wave lambda) follows the roof inside to make an upside down v shape
The feedpoint is a simple chop block which can be screwed under the roof apex but don't forget to solder the braid and the centre core so that they are 'tinned' and will give a good connection
:D At the end of the feeder(at the feedpoint )its a good idea to use an air choke which can be achieved by wrapping about 5 turns of the feeder around a piece of 10 cm soil pipe more info here http://hamuniverse.com/balun.html the benefit of this is to prevent the feeder from radiating a signal and thus reduce the chances of causing interference plus more of your useful signal will be radiated from the antenna
http://www.transmission1.co.uk/forum/vi ... 4&start=15
:D some pics of my inverted v on here hope that helps
Re: loft antenna
Posted: Mon Oct 31, 2011 8:44 am
by Adriano9966
:D oops you need to go back one page to see the pics good luck
Re: loft antenna
Posted: Mon Oct 31, 2011 5:01 pm
by porky.69
very good idea adriano, might give it ago in the new year *King*
Re: loft antenna
Posted: Fri Nov 04, 2011 10:41 am
by needle bender
well,bin helping an old breaker back on cb radio after 20 years...local council regs dont permit him to have a large antenna..so after trying several mobile antenna's in his loft have settled on a half wave silver rod mounted horizontal...the good news is it works very well...he was happy to be able to copy a breaker about about 15 miles distant last night,,good signal and mod report...gonna spend the day with him sunday and see just what its capable of...thanks for info on inverted v adriano...might give it a shot sometime...have made antenna's in the past with varying results none that i can conclude being better than the usual commericial types.still all good fun trying.. :D
