Hi Folks,
If you own the Midland G7 radios, there is a very simple mod to make these radios even better. Remove the belt clip and battery, remove the 3 screws holding the back cover on. You should now be looking at the circuit board. On the right hand side are 3 wire loops, snip the top one raises the TX power to 3 watts high and 1 watt low, snip all 3 and this opens up the channels. Re assemble and when you switch on... the channel display will still have the 1 to 8 channels (P1 to P8), then you have 69 more channels numbered 1 to 69. These channels are in the 70cms amateur band so you should have a licence to use them. That said..if your in a busy area and the 8 normal channels are chock a block..this gives you the option to get away from the masses and earwiggers. I post this as INFORMATION ONLY AND YOU CARRY OUT THIS MOD AND USE THE EXTRA CHANNELS AT YOU OWN RISK!
Regards
Budgie
Diss
20
MIDLAND G7 EXTRA CHANNELS AND HIGHER TX POWER MOD.
- Bionic Budgie
- Motor Mouth!
- CB Handle: Bionic Budgie
