Cant get no decent SWR reading
Posted: Sat Aug 04, 2012 12:49 pm
by UnderCover Runner
Was trying to get my mobile CB set up again, and I cant get a low SWR reading, Its all 10+ from Ch1 to CH40. No matter ho much I raise the Antenna.
Ive tried lowering the antenna that came with the CB with no joy, and its much the same with the Orbiter HD Centre load.
As Im a total newbie on this is there anything I have missed?
Is there any where close by ho can sort it?
Cobra 19DX IV EU
5 inch mag mount (mounted on roof)
Dom
Re: Cant get no decent SWR reading
Posted: Sat Aug 04, 2012 2:58 pm
by Guzzy
10:1 sounds like a cable short.
Check the PL259 plug is soldered to the coax correctly and that there is no shorting occurring between core and shield.
Check the coax goes into the antenna base correctly, sometimes these can be pulled out a bit and then short or lose connection.
Posted: Sat Aug 04, 2012 5:23 pm
Checked the connection on the cable that I use for the SWR meter to the CB and the connection has split. So Im gonna get a cheap soldering iron and try n fix it.
Couldnt check the coax to the antenna base as its moulded!
At least I know what Im looking for no
Posted: Mon Sep 03, 2012 11:59 am
by Strumalong
You need to check continuity with a meter. This will tell you if there is a short or open cerci it any where
Posted: Tue Sep 04, 2012 6:11 am
plus make sure the meter is in the rightway
