Swr off the scale
bigtomgorman
Heres the thing, i bought a midland 78+ radio and got a thunderpole orbitor fitted on a magmount no my car roof. Connected the swr meter turned it to set flicked it over and the needle nearly bent right over in the red, what am i doing wrong
make sure the swr meter is connected the right way round check all leads for a short includeing the patch cable
sputnik
CB Handle: Sputnik
Same prob here?
I bought a DV27 kinda mount and cable complete with a 7 foot firestick off here, guess I bought the wrong mount? lol - anyways, my dial-a-whip or firestick wont show an SWR below the end of the scale, I used a test meter on the continuity setting where it whistles if there is continuity, everything checks out and there are no open bits anywhere nor is there any short circuits in the pre fitted plugs, if I reverse the plugs on the SWR meter there is no difference really, when I calibrate the needle and flick it to REV it almost stays where i calibrated it? - I have a new SWR meter on it's way as we speak, apart from that I have read in vast amounts, it's a mount grounding problem or as good as? even though it's actually touching bare metal inside due to the fact I sandpapered the paint off (Astra Van) does any one think I should further ground the mount to the negative battery pole just for good measure? OR as suggested all over the place, the feed cable should be 18 feet long - I make it 12 feet if you devide an 1/2 wavelength with the velocity of the cable, ie, 18/.66 = 12 feet, who says what?
Sputnik :-)
7 ft firestick are mainly set for the mid band freq so it probably will need a bit of trimming but use the meter on the 2 frequancys which are the farthest apart ie 1 on mid band and 40 on the uk you should get a differance between them to tell you to trim it dont worry about the cable length hope this helps
