Basic CB receiver
Posted: Tue Jan 29, 2013 11:21 am
by JohnGOF
For all of you this should be a very basic request for help!
I am not (currently) a CB user, but my local church is now transmitting services on CB. The supplied £15 receiver is, not suprisingly, of poor quality and given the location of the house, reception is not good.
Is there a receiver out there which is competitively priced, mains powered and ideally have a reomote control?
Have I given sufficient detail?
Many thanks.
John.
Re: Basic CB receiver
Posted: Tue Jan 29, 2013 4:25 pm
by andy@thunderpole.co.uk
Hi John,
The only 'receive only' CB radio we do is the Intek CBM450...
http://www.thunderpole.co.uk/mobile-cbs ... 0-kit.html
It is 12v powered so would require a 12v mains power supply, but it won't draw much power at all so that shouldn't cost you much.
I would say it should work a lot better than the £15 receiver you have already.
Posted: Wed Jan 30, 2013 4:35 am
by 26-TM-037
From hearing the CADS broadcasts myself they don't always seem to be broadcasting on a recognised CB channel, many times I hear them for example on say 27.442 mhz not always ending in 0 or 5.@ JohnGOF, are you in England or Ireland?.....perhaps you don't hear the broadcasts that well because the receiver you are using is not on the exact same frequency as the broadcast?......just a thought and observation
Posted: Wed Jan 30, 2013 8:53 am
Posted: Tue Feb 19, 2013 6:54 pm
by JohnGOF
Hi Folks,
I've had a look at the CMB450 and it looks like a good option from performance and price. This receiver is not for me - it is for an elderly relative - hence the request for remote operation.
I like the idea of disabling the transmit functions to widen the selection.
Situation is in Ireland, County Derry.
Thanks.
Posted: Wed Feb 20, 2013 12:43 pm
Posted: Wed Feb 20, 2013 4:15 pm
by JohnGOF
Ok. So a remote is a bit out of the question.
A mains power supply is next. The cheapest on the site is nearly as expensive as the receiver!
Any thoughts?
Posted: Wed Feb 20, 2013 4:22 pm
by JohnGOF
Just realised - another, but cheap, supplier sells a remote mains power switch for around £10.
I could plug the power supply into it and problem solved - I think?
Posted: Wed Feb 20, 2013 10:22 pm
by porky.69
omg
Posted: Thu Feb 21, 2013 12:12 pm
Posted: Thu Apr 04, 2013 9:21 am
by JohnGOF
I bought the Remote Controlled Mains Socket Set from another source.
It works the CBM-450 perfectly so that my relative does not need to move to switch it on.
Put together - a perfect solution for this situation.
Posted: Thu Apr 04, 2013 1:38 pm
by porky.69
JohnGOF wrote:For all of you this should be a very basic request for help!
is this legal ????
Posted: Thu Apr 04, 2013 2:06 pm
Posted: Thu Apr 04, 2013 7:29 pm
by porky.69
thanks andy. i think its no different to having a music player on channel 19 CRAZY
when the skips running there a nightmare !!!
