Sigma Excalibur - advice please.
Posted: Wed Feb 06, 2013 12:39 pm
by hobgobblin
Bit limited on antennas at my qth. Can't have big outdoor ones for a number of reasons. Anyway, got a Sigma Excalibur loft antenna. Instructions said to use patch leads of a precise measurement. I chose the shortest (8'10") and everything appears to be good. This morning I connected a swr meter and short patch lead and the swr reading was high. Would putting the meter and lead in affect it? Any advice and comments much appreciated.
Re: Sigma Excalibur - advice please.
Posted: Wed Feb 06, 2013 2:17 pm
by hobgobblin
Silly me! Just Googled stuff to do with swr... I should've turned my mic gain and power knobs right down!! Will try again. :oops:
Posted: Wed Feb 06, 2013 3:15 pm
no power and mic gain should be as you normally use the set not turned down as it will give you a false reading
Posted: Thu Feb 07, 2013 12:14 pm
by hobgobblin
Think I might know what's wrong. I've got the antenna mounted on the wall with the top nearly touching the camp ceiling. I'm getting a secondhand tripod and will mount it on that so it can stand away from walls and ceilings. Do you think I'm on the right tracks?
Posted: Fri Feb 08, 2013 12:10 pm
by hobgobblin
The saga with this set-up continues! Just measured the bespoke lead I had made at a ham radio shop - it should've been 8'10" and it's way over 10'!! Got them phoning me this arvo to sort it. Will it have damaged my rig? Because if it has they'll be buying me a new one!!!
Posted: Fri Feb 15, 2013 11:44 am
by hobgobblin
Thinking I'm not going to get great results with the Excalibur so I've ordered a Double Spooky Bazooka from America. Anyone want the Excalibur? It'd make a good truncheon - if you cut it in half it would make two. :wink:
Posted: Tue Feb 19, 2013 4:44 pm
by hobgobblin
Got a new rig with a built in SWR meter - tested the Excalibur today and it's a perfect SWR reading on CB and 10 meters! Explanation anyone? :)
Posted: Wed Feb 20, 2013 12:45 pm
sounds like a dodgy meter or patch lead
Posted: Thu Feb 21, 2013 1:52 pm
by wildfire
hi hobgobblin,
i had a mate who had a Excalibur did not stay up for long as it was not inpresive & don`t work as well as other antennas but personally i think you would have done better with a boomerang but how have you got the Excalibur mounted have you ever thought about mounting it on a Cranked Aerial Mast with a stand of brackets
Posted: Thu Feb 21, 2013 4:47 pm
by hobgobblin
Thanks for the advice. Yeah, that'd been a great idea. Not allowed outdoor antennas where I live. Have ordered a Double Spooky Bazooka that I'm thinking will be much better than the Excalibur. Will post on here how I get on with it.
Posted: Thu Feb 21, 2013 6:18 pm
by wildfire
yeah let us know how you get on with it m8 would be nice to see & hear some good results but if it all goes pear shaped don`t worry as there are many antennas what are specially built for lofts & here they are below,
the 1/4 wave or 5/8 wave boomerang wave, mini GP, signal keeper, DV 27 with ground plane kit not sure if they build ground plane kits for DV 27 anymore as i used to own one,
but what ever happens good luck with your double Excalibur buddy :wink:
