decent ground plane
Posted: Fri Apr 05, 2013 5:25 pm
by lyron
anyone got any suggestions on how to get a decent ground on our disco 1. :oops: the antenna is mounted on the gutter at the rear of the car.
if i do need an extra ground where do i take it from/to.
ron. :mrgreen:
Re: decent ground plane
Posted: Sat Apr 06, 2013 9:52 am
no you should be absolutely fine providing the grub screws have bitten into the inner of the gutter if the meter is saying its a ground plane problem then make sure the whip is std
Posted: Sat Apr 06, 2013 5:36 pm
by lyron
thank you for the quick reply. will check the grub screws and all other connections, and update later.
ron. :mrgreen:
Posted: Sun Apr 07, 2013 4:28 pm
by lyron
quick update, the swr reading is channel one 1.5.
channel 20 1.5.
channel 40 just fractionaly under 2. raised the attena up as high as it will go. but cannot get it any lower. are these readings ok. advice is always greatfully recieved.
ron.
Posted: Mon Apr 08, 2013 6:25 am
yes they will do fine
Posted: Mon Apr 08, 2013 9:22 am
by lyron
many thanks for putting my confused mind at rest :oops: :oops:
ron.
Posted: Tue Apr 09, 2013 12:33 am
by DEANO3528
I use a 4' Firestik mounted on a bracket behind the spare wheel using the top left carrier bolt to hold it. Seems to get out well and no swr issues. Used to use a gutter mount on most of my Range Rovers and that was fine too.
