Squelch Question
Posted: Fri Sep 06, 2013 1:05 pm
by somersetboy
I've recently fitted my rig in to a new lorry. The squelch seems ridiculously high. By this I mean that I have to have the squelch knob turned right against the stop before I can get rid of the hiss.
What is causing this as i'm squelching out the people need to speak to.
Re: Squelch Question
Posted: Fri Sep 06, 2013 6:28 pm
by Dragonfly
In my truck i get quite a bit of interference when the lights are on and the fridge is running but the interference moves channells each time i change trailors so some trailors its ok on 19 , other trailors 19 is a wright off .During daylight hours the radio is usually not bad with the odd trailor giving a bit of ABS noise on the CB when i brake .
Posted: Sat Sep 07, 2013 10:11 am
hi squelch control is interference from th wagon takes a bit of finding but can be done remove fuses 1 by 1 til it disappears then you know the circute it is on
