Antenna and roof rack
Posted: Thu Sep 26, 2013 8:27 pm
by steve70
Here's a pic of the roof rack on my van
Would sticking a mag mount on the roof cause any problems given the vicinity of the bars of the rack? They are about 3 inches above the roof.
It's a company van so I don't really want to attach anything directly to the roof rack.
I'm using one of these at the moment
http://www.thunderpole.co.uk/antenna-ma ... g-kit.html which I have noticed a bit of difference in receiving when stuck to the rack, but I'm thinking about getting a Mini Orbitor and it's 6" mag would be a bit big for sticking to the rack.
Am I making any sense?
Re: Antenna and roof rack
Posted: Fri Sep 27, 2013 7:54 am
Posted: Fri Sep 27, 2013 1:38 pm
by steve70
Well I didn't really want to mount anything to the roof rack but if the antenna can easily be unscrewed when not in use then I might take your advice.
Do these mirror clamps come with protective bungs?
Would need to stop the rain and what not getting into it.
What about protecting the pl259 plug.
Do you use amalgamating tape like you do on a homebase antenna.?
Posted: Fri Sep 27, 2013 2:12 pm
Posted: Fri Sep 27, 2013 2:20 pm
by steve70
How does it prevent water and debris ingress then ?
Posted: Sat Sep 28, 2013 10:09 am
Posted: Sat Sep 28, 2013 11:43 am
by steve70
OK thanks.
Posted: Sat Sep 28, 2013 7:44 pm
by steve70
Do these mirror mount kits only come with one plug?
Posted: Mon Sep 30, 2013 4:42 pm
Posted: Mon Sep 30, 2013 6:44 pm
by steve70
I ordered separate mount and 3m patch coax.
I couldn't work out why the kit only came with one plug when you need one for each end.
Posted: Tue Oct 01, 2013 8:05 am
Posted: Tue Oct 01, 2013 7:15 pm
by steve70
Cheers for your help stampman, I see what you mean about the mount antenna conection just being a nut
Got a Super Nova set up now but SWR won't go down much below 3 on 40 and 2 on 1.
Do I need to cut the whip down?
Posted: Wed Oct 02, 2013 7:45 am
Posted: Wed Oct 02, 2013 8:32 pm
by Dragonfly
You must have got this type of mount and as you say the coax needs a PL259 plug on both ends , Just tape up the plug to keep the weather out .
Posted: Wed Oct 02, 2013 10:07 pm
by steve70
Cheers Dragonfly. Yes I have a similar mount. The one with the 4 bolts.
Don't want this thing flying off at 90mph do I ;)
