Stuipd Question - SSB ?
salop sniper
Folks,
My radio knowledge can really be written on the back of a postage stamp. How ever I am reading alot reffering to this "SSB".......... What does SSB stand for and what is it and what does it mean/represent for CB use in the UK ?
I gave up on my CB after 2 months of calling and getting no contact, but am not happy with that and want to return to it as some folks are getting some fantastic ranges of communications . But I want to understand far more about it !
ATB
Matt
Rizzer
CB Handle: Dusty Bin
SSB stands for Single Sideband and is just another mode of transmission like AM (Amplitude Modulation) and FM (Frequency Modulation).
In the most basic terms SSB transmitters only transmit one half of a waveform then the full waveform is reconstructed by the receiver. This does although for longer transmission distances and SSB is used for the majority of voice communication of the HF bands including military and ham radio.
clouseau
CB Handle: Clouseau
oddly, SSB is the only mode of transmissiion that benefits from louder audio! meaning the louder you shout the more power you transmit, subject to the output limit of your transceiver of course. AM also sees some benefit, and strictly speaking SSB is an AM mode anyway. when you transmit using SSB the Signal meter needle or LCD will alternate up and down in response to your voice, just as the recording level meter would on an old hi-fi system if you plugged a microphone in and talked into it. amplified microphones otherwise known as power mics, have very little benefit on FM but prove more usefull on AM modes of operation. as rizzer has explained SSB uses less bandwidth than either an AM or FM signal, which is why there is actually room enough for two sideband channels, being USB and LSB. upper sideband or lower sideband, but the latter is rarely used on any frequencies above 10mhz regardless of what radio service it is. and yes SSB is the most common mode of transmission for radio amateurs and so the best for working long distance, because its more efficient than the other modes, despite being one of the oldest forms of transmission.
