Best ariel please?
Posted: Sun May 11, 2014 10:01 am
Hi I'm a truck driver using a Thunderpole T-1000 with a DV27 on the original Daf mount which is behind the cab so the Arial is in between the cab and the trailer it's a super space cab so the original Daf Arial was lower than the roof hence why I changed to the DV 27 which is slightly higher than the roof the range I get is about 3 miles is there a better Arial I could use or should I stick to this the rig output power is just over 10 watts (radio was tuned in Italy) mainly use AM any advice appreciated thanks.
