static problems
Posted: Sat Nov 14, 2015 8:48 pm
many yrs ago it was our cb's causing the problems.
now I'm hoping someone can help me out here.im running a anytone cb radio,sirio gainmaster.
I got it all set up,swr 1.2 across the bands perfect.
the problem I have is really spoiling how well I receive.my transmission is excellent.i was getting a constant +10 through every band.
I do have a cctv system which I was told could be the problem.i managed to cure this using two ferrite rings on the power supply to this device and it has stopped the interference.
I'm still getting 7 pounds of static sometimes 9lb constantely making anyone under this hard to hear and only local stations being clear.ive done what a few have said turned off the house supply and run my radio on a car battery to illuminate the problem but its still occurring,
ive took a ground from my power supply to radio no different.
would an earth from the radio or earth from ariel to a ground rod help?.
I have noticed when there is no antenna connected the signal is zero.
if I place a 6" piece of wire in the radio antenna socket,i get 30+ of hash/static.
I'm lost and really want to get back into my cb radio after a very long time out.what chatting I'm doing is within a mile radius at the moment.anything over this is a struggle.
really hope you guys have a solution.if I cant find a solution then I'm afraid I might aswell give up.
I'm not a quitter lol,i really have tried everything without success for this past two wks.only thing left to try is earthing to ground.
many thanks mark.
73's.
many thanks mark.
73's.
