SWR,ING
spectra
Wheres the best place to locate a swr meter when swr,ing, the reason being, when i go to swr my dv-27 with groundplane kit in the loft i put the meter on top of the rig but if i move it off the rig the reading moves higher,do i need to locate the meter at a said distance away from the rig.
move it away
:D :D :D :D :D
spectra
Cheers for that, up to the loft again !
benifits of cb keeps you fit
:D :D :D :D :D
spectra
Too right especialy when you,ve got two slipped discs :cry: [/u]
colins good on ladders dont know if he makes house calls though he used to be a window cleaner at empire state building the moved to portholes on jumbo jets
:D :D :D :D :D
charlie oscar
if you can you should put the swr meter at the antenner not the radio :D .....and which goes without saying never keep it in line once you have the correct swr.
