High see readings
Posted: Wed Jan 10, 2018 9:38 pm
by Balertwine
I removed my cb and siro antenna from my truck to fit I to newer model. I wired up to the same connections as some of my colleagues only to find out later that it was a 24v connection. The fuse had blown on the live wire by this time, but the cb lit up. I then bought a24v dropper and wired through this, the swr readings were 3 plus on both 1 and 40.... I earthed the guttermount, bought new anttena's but still high readings. I took my cb to a guy who tested it at his home and it worked fine. I then bought a magmount from him and tried that, the readings were even higher. The latest is I removed the cb, wired a cigar plug and tried that. The swr readings are now off the scale. I tried to earth the cb direct to the truck body, but it wouldn't even light up when I tried this. I am at my wits end, do you have any recommendations??? Midland Alan cb.
Re: High see readings
Posted: Thu Jan 11, 2018 9:37 am
Re: High swr readings
Posted: Thu Jan 11, 2018 8:09 pm
by Balertwine
The cb is 12v, the connection. I tried it connecting to 12v cigar point.
Posted: Fri Jan 12, 2018 8:15 am
Posted: Mon Jan 15, 2018 8:22 pm
by Balertwine
Still got the high readings, but CB working good. Hearing my mates miles away, using a small (other company) cb.
Posted: Sat Nov 23, 2019 10:35 am
by AppleTree
Not always true, they come with both 12 and 24v sockets nowadays.
Balertwine wrote: ↑Mon Jan 15, 2018 8:22 pm
You can try a different meter incase your one is not working properly.
If I was you I would start again from the start. Remove the cable and run a new cable, new PL259's as well.
