Maycom EM 27 @ Home
stu
Hi There.
I am going to purchase the Maycom EM 27 CB.
My idea is to use the EM27 at home, obviously they use car cigorette lighter power adapters.
What can I do to get power to the CB from my wall socket?
Please note, I am a learner to this.
Any help would be appreciated.
Thanks.
Stuart
Paul (2H3CK)
Hi Stu,
You'll need to pick up a power supply which i'm sure you can get from this site. The power supply converts the 230V mains AC voltage and transforms it down to 13.8V DC. For just a rig such as the Maycom a 3 Amp supply should suffice.
Hope this helps!
All the best....P
All the best.....73....P
stu
Thanks for the speedy reply.
Cheers.
Hi Stu,
The power supplies are on this page...
http://www.thunderpole.co.uk/power_supp ... andard.htm
The 2-3amp should suffice.
Regards,
stu
Thanks Guys.
Just out of curiosity, if i wanted to buy a better rated PS,
Is it possible for me to go the extra and buy the Palstar PS-06?
Would it do any harm, E.g - supply too much power and blow the CB?
Regards,
Stuart
No it should be fine. As long as the voltage is 13.8 Volts it will work.
There is just more current available for any connected equipment to use.
I hope this makes sense?!
stu
Yes, I understand that loud n clear m8.
Thanks.
What I'll do is get the M-490 Intek CB and the PS-06 Palstar.
The only one other thing I had in question was .....
Sorry to be a pain...
The Distance/Range I could get with the DISCOVERY III 1.75m Aerial?
Thanks.
Stuart
That is quite a difficult question because the answer depends on many things, local terrain, conditions and what vehicle it is mounted on.
As a rough guide though I would say up to 10 miles should be attainable in good conditions.
stu
Hi Andy.
Yea, I know what you mean.
I have read on the other threads, a couple of guys were using A99 type of aeriel, they were saying the were gettin a really good signal.
I was gonna invest in one of those.
I know this will be a silly question, but,
Is it possible to get an aeriel that will transmit around the world
Regards,
Stuart
tomcruzz
