Unsteady SWR.
Posted: Thu Jun 07, 2007 5:50 pm
by Asterix
Can anybody please tell me why my SWR varies so much especially on channel one?, one minute its 1.5 and if I move my mike around it can go up to 3.5, (more so if I move my mike upwards ). If I touch the rig body or the mike lead it seems to drop and steady. I had the arial mounted on the roof bars, then I put in another earth lead from them to the body of the car, It made no difference, so I put a mag mount on the roof which never made much difference either! I changed the arial for a firestick, it was better but still move's about, I don't Know what my true swr readings are at this moment, Any Idea's Anyone?.....regards Asterix.
Posted: Mon Aug 13, 2007 11:02 pm
by tranexneil
It would seem you have a leaky RF path !
If you have tried known good antennas and the swr is of know stock then id hazzard a guess that the decoupling capacitors around the antenna socket of the radio are faulty or probably broken.
this is assuming that the roof of your car is metal and NOT fibreglass !
check also the roof bars are actually connected to the ground/earth of the car !!
Regards
Neil
Re: Unsteady SWR.
Posted: Thu Aug 16, 2007 6:43 pm
by NToombes
Asterix wrote:Can anybody please tell me why my SWR varies so much especially on channel one?, one minute its 1.5 and if I move my mike around it can go up to 3.5, (more so if I move my mike upwards ). If I touch the rig body or the mike lead it seems to drop and steady. I had the arial mounted on the roof bars, then I put in another earth lead from them to the body of the car, It made no difference, so I put a mag mount on the roof which never made much difference either! I changed the arial for a firestick, it was better but still move's about, I don't Know what my true swr readings are at this moment, Any Idea's Anyone?.....regards Asterix.
Hi
My (other company) Minor is doing exactly the same!
I tuned it on channel 20 to about 1.2:1 and thought great, will key up now and put a call out on channel 19. As I lifted the mic to my mouth the swr shot up from the 1.2:1 to about 4:1. I noticed as the mic lead dances about, he swr changes to.
I am using a brand new Apollo mag mount from Thunderpole. The SWR is new from there to.
Posted: Thu Aug 16, 2007 7:50 pm
sounds like a bad earth
:D :D :D :D :D
Posted: Thu Aug 16, 2007 8:19 pm
by NToombes
stampman wrote:sounds like a bad earth
:D :D :D :D :D
Well, its a brand new radio and connected into the cigarette lighter socket.
The only thing I had to modify was to remove the SO239 from the rear of the radio and put a 6" length of coax cable into its place as I dont have enough room behind the radio to take the PL259. I double ensured all connections and solder joints were good.
I have suspended the radio from its brackets in the glove box and its being a sodding nightmare. I am close to kicking seven bells out of it.
If only my glove box was more that 155mm deep!!
Neil
