Need help with choosing an antenna
Posted: Sat Aug 18, 2018 5:38 pm
by Diesel Dave
I have recently purchased a midland Alan 100 plus C.B. radio and i am looking for a antenna to use with it. i have been looking at the Thunderpole super nova but when i went down to my local C.B. radio shop i was told that I shouldn’t be using a antenna that is under 3.5 foot long as it will mess up my radio and then they pulled out a massive antenna that they recommended. If anyone could help with whether what the shop has said is true or not and whether the super nova is a good antenna to use it would be great. Thanks.
Re: Need help with choosing an antenna
Posted: Sun Aug 19, 2018 10:01 am
Posted: Sun Aug 19, 2018 10:51 am
by Diesel Dave
Ok thanks, would i need a swr meter for that or would it be possible to do without for example when a antenna says it is swr pre tuned. Thanks
Posted: Mon Aug 20, 2018 10:06 am
Posted: Mon Aug 20, 2018 2:24 pm
by Diesel Dave
Ok thanks
Posted: Wed Apr 17, 2019 4:30 pm
by Techuk
I am setting up a base station and will put up a silver rod type. Do you get much interference from them.? how high should I get it? I hope to get it fitted on a pole above the eves of the house. I will want to use sideband as well as UK FM.
Posted: Thu Apr 18, 2019 9:56 am
Posted: Thu Apr 25, 2019 3:15 pm
by Techuk
Great just got my 1/2 wave silver rod need to assemble it now. Looks straightforward can i use amalgamating tape to seal each section from water? It wont affect the SWR reading of the aerial... guess i can use it on the plug too!
Any ideas of getting a standoff and a pole attached to my gable end? will a local TV aerial erector do it for a price? I will sus this out
Posted: Thu Apr 25, 2019 3:24 pm
by Techuk
update on the aerial erector this is sorted and will get done soon... nice
Posted: Thu Nov 21, 2019 6:33 pm
by Dave 2000
I use the self amalgamating tape once or twice a week, try to get the stretch right, if you go too tight it will eventually shrink and tear into a split.
regards
Dave
Posted: Fri Feb 07, 2020 10:27 pm
by wildfire
Diesel Dave you will also need a patch lead for you swr meter to swr your antenna in with buddy
Techuk
I hope you have put some garden canes into your silver rod as they will help your antenna to be more stable in strong winds hopefully it will live through our bad weather
