homebase cb radio antenna
Posted: Fri May 24, 2019 11:23 am
by rollerball
hello.rollerball here.has been a long time sice bought cb radio and items.was back in 80s and 90s.am geting old now but decided to have another go at it.only problem got is the housing complex i live in wont allowe eny type of cb aerials outside so need somthing to run the recent 80 channel cb radio have got.and wanted to know if eny members on here had eny advice on eny type of maybe a loft aerial or somthing else could use?.thank you.
Re: homebase cb radio antenna
Posted: Mon Feb 10, 2020 8:33 pm
by wildfire
Hello Rollerball
& welcome to the forum & hope you enjoy your stay buddy & I've sent you a pm 😉
Posted: Fri Jun 05, 2020 3:35 pm
by RSGB280662
Good afternoon Dennis here QTH Northampton.
I spent many years on the CB and made many good friends over that time, some of which had the same issue you have with antenna and housing regs. / rules.
There are many excellent antenna avalible on the market, which are out of sight or "stealth" the book l would recommend is "written by Steve Nichols and called "stealth antennas" or if you simply want to go out and buy a great antenna for 11m band for the CB work, just go on u tube and look up "11m magnetic loop antenna" there are even instructional videos on how to build your own "11m magnetic loop antenna" have a go it is easy fun and very rewarding to get contacts on a home built antenna.
You may find this of use.
What the CB community generally refer to as the 11m band or freeband is considered to cover is 25 MHz to the beginning of 28 MHz although most activity happens around 26-28 MHz.
Hope you find what you are looking for and enjoy your radio.
73 Dennis
