aerial for motorhome
diesel cowboy
Hi guys, I am looking for advice, I have a coach built motorhome, it has no metal in the bodywork other than an aluminium bicycle rack on the back wall. I am wondering what would be the best antenna to get for the motorhome
- wildfire
- Motor Mouth!
- CB Handle: wildfire.
motorhomes are a bit of a bugger for mobile cb mind blowing but we always get there as we're all here to help each other I'm surprised nobody has commented yet lol
okay let's think basic for a motorhome I would think about a bar mount as motorhomes are fibreglass or something useless rolls eyes
I would suggest a bar mount
https://www.thunderpole.co.uk/mirror-bar-mounts.html
with a 4ft thunderstick
https://www.thunderpole.co.uk/medium-cb ... k-4ft.html
but you will need a swr meter with a patch lead & coax from your antenna to the swr meter buddy
Depends what you are expecting from the setup. If your rv is chassis-front end based then a boot lip mount on the edge of the bonnet is quite common in europe.
I have one car with a 'stick on glass' antenna on the windscreen. It gives a range of 2-3 miles and has been there 14 years without issue. I have fitted a similar antenna to the body of an old fibreglass ambulance, but getting one half stuck directly opposite the other when you can't see it is a bit of a game.
A 'Saturn 5' type would clamp to your bike rack and not need a ground plane, but again the range would be limited.
Another possibility (though I've not seen them for sale for a long time) would be mirror mount with a built in ground plane. They were intended for use on trucks with grp cabs. Don't know how good they are, never fitted one, but you could put one each side for the twin trucker look!
There used to be 27mhz boat antennas, again designed for grp mounting but not seen one in years.
Please let us know how you get on.
One person in ten understands binary. The other one doesn't.
