Antenna resistance
Posted: Thu Dec 10, 2020 1:13 pm
by pdes
I am having problems getting my SWR below 3! I have done all the usual tests with a meter and have proved the integrity and earthing of the cable. My question is, on a Sirio Hi-Power 3000, I am measuring a resistance of 1.8 ohms between the centre pin and outer/earth casing. Is this normal?
Re: Antenna resistance
Posted: Mon Dec 14, 2020 9:20 am
Yes that is completely normal, as you are measuring across a loading coil.
It will measure low resistance at DC, but the impedance should be 50 ohms at the frequency you transmit at. Impedance is a bit like resistance but also takes into account the capacitance and inductance of the antenna (thinking back to my BTEC electronics classes!)
The SWR could be high because of a number of things: antenna length, ground plane, deflection from other materials.
Is the antenna away from other obstacles with a good groundplane? https://www.thunderpole.co.uk/cb-radio- ... plane.html
And is the reading consistant across the frequency band (channels 1 to 40), if not the antenna length may need adjusting.
Hope this helps,
