Confused over grounding!
Posted: Sat Jan 09, 2021 12:06 pm
by pdes
Could someone please clarify for me the correct grounding of a gutter mount. I have assumed that there should be a clean earth from the coax to the car body through the gutter mount. However, while trying to check all connections, I have noticed the isolation ring in the mount which effectively prevents contact between the earth of the coax and the car body. Is this correct? Should the earth of the coax be electrically isolated?
Re: Confused over grounding!
Posted: Sat Jan 09, 2021 9:46 pm
by andy@thunderpole.co.uk
The earth connection of the coax should be connected to the ground on the gutter mount. The isolation ring should be there to insulate the inner of the coax not the outer.
Hope this helps.
Andy.
