24v bus 12v cb can't seem to get ground plane..
Posted: Mon Mar 15, 2021 11:36 am
by Biscuit
Hi
Hope someone can help me..
I have a 24v bus (1973 aec reliance) i have installed a 12v cb using a 24v-12v voltage dropper. I have a mirror mounter ariel. I think the problem is probable because i think the frame that the mirror is mounted to is wood covered in fibreglass and most of the bus body is wood and fibreglass so i don't think there is a connection from the mirror to the chassis. Also i am not sure if connecting the mirror to the chassis would help as i am using the voltage dropper would also need a long wire which i have read can become part of the ariel and mess things up. I currently only get about 300m line of sight range to my friends motorhome with cb installed..
Can anyone help please?
Re: 24v bus 12v cb can't seem to get ground plane..
Posted: Mon Mar 15, 2021 1:12 pm
by Biscuit
Sorry also wondering if I can make a no ground plane mirror mount just by drilling my existing mirror mount and adding a second antenna pointing down? If so any tips please? Any idea what may be a ideal length for the second antenna? Or how to tune - do i tune both antenna one before the other etc. Had a look online and it looks like that's all the thunder pole no ground plane mirror mount is.
Posted: Mon Mar 15, 2021 7:12 pm
by Hair Bear
Hi, there is a stick-on window mounted antenna which has a 'useable couple of miles' range, I've had one on my car for years but only use it when the roofbox is on and removal of the roof antenna is required. Another option is a mirror mount that was designed for use with ERF and Foden trucks with glass fibre cabs. This consists of a bar mount with what appears to be a small handset type antenna pointing down to act as the groundplane. Never used one, don't know how well they work, can't remember who made them, may be called an ERF kit.
Take a look at this link
https://www.thunderpole.co.uk/cb-radio- ... plane.html
There is a photo of one above the statement 'What Is A Ground Plane'.
Edited to add...
Just read your second post. No idea how that would work. Maybe the mods can help.
A thought, if you're doing a panel off restoration why not get a roll of bare copper wire, attach the end to the mirror mount then do a complete circuit of the vehicle clipping the wire to the exposed woodwork, then return to the other end of the mirror mount. It should work. Or, again with the panels off, put a large thin sheet of metal under one of the roof panels then drill through and fit a stud mount.
Posted: Mon Mar 15, 2021 7:37 pm
by Biscuit
Thanks for your reply! I've been looking at the erf kits you suggested - they look exactly like the mirror mount i am using with a second ariel attached facing down - i have one of those ariel's too so i am going to try make my own tomorrow i think. I am just a little confused as to what length the second ariel should be. In the pics it looks short so i will try measure from pic and replicate the length. Will post on here how i get on. Also a bit confused as to weather i tune the bottom or top or both at same time to get correct swr - trial an error I guess. Again will post on here how i get on...
Posted: Mon Mar 15, 2021 8:38 pm
by Hair Bear
Be aware that the thicker part of what you see is a loading coil winding and only the manufacturer is likely to know the length of the wire in it.
Posted: Mon Mar 15, 2021 9:46 pm
by Biscuit
Is the length of a downward pointing ariel important? To make a no ground plane ariel...
If so any idea what the ideal length would be?
Posted: Mon Mar 15, 2021 10:02 pm
by Biscuit
This is what I am intending to make -
- s-l400 (2).jpg (7.1 KiB) Viewed 16887 times
It looks like the same mirror mount i already have but with a extra downward pointing antenna which looks like one i already have spare. I am planning to drill a extra hole in my mount to add the extra antenna. Can anyone see any problems i might have?
Posted: Wed Mar 17, 2021 3:16 pm
by Biscuit
Hi - just to let you know a friend came with a swr meter and turns out i had a good reading. He also checked my friends motorhome and turns out it was him that had the problem - his cable was coiled to take up excess cable - removed the coil and now he has good swr readings too...
Not tested yet due to lockdown but when one of us goes out next will test but i suspect the problem is solved. - thanks to all that tried to help!
