Back with a passion
Posted: Sun Jun 26, 2022 11:32 pm
by Revomikey
So it's been over 4 years since Andy helped me with my dipole. Things came and went but in the back of my mind was the aching to get back into cb
After much debate and thought i now have the t800 thunderpole rig, it's a great piece of kit, i obviously haven't tuned it up.
My dipole was doing well but i thought i can go better, tomorrow mr Amazon is delivering my 5/8 thunderpole, it's going on a 3m pole mounted to a tripod. This way i don't have to comply with regs and technically it's a temporary structure.
Looking forward to getting it up and running tomorrow after work.
My son is also loving it so I'm going to put my old cbx in his room and a mag mount in the attic fit local chats, how big a ground plane do you think I'll need? Can i just throw some metal under the mag mount?
Cheers dudes
Re: Back with a passion
Posted: Mon Jun 27, 2022 10:38 am
Hi and welcome back to CB!
I would think any sheet metal bigger than say a foot square will work, but obviously the bigger the better.
Andy.
Posted: Mon Jun 27, 2022 10:44 pm
by Revomikey
Thanks again Andy, the 5/8 arrived nice and early so after work i got to it.
The pen marks on the poles gave me an instant 1.1 on the swr meter, faultless, i didn't even have to adjust it once.
I got some good copies from a good few miles away so was happy with that.
My son then started nagging me to fit the harrier cbx in his bedroom, couldn't find a big metal sheet but found a largeish sheet of mdf and wrapped the wife's tin foil around it. 1.2swr, good enough. He's gutted he's not getting far so may put the dipole in the attic, that has to be better than the magmount modulator right?
Looking into ssb now, i think that's next on my list.
Posted: Wed Jun 29, 2022 7:51 pm
by Revomikey
Well Andy, everyone else, I've created a problem. I tried to install some bamboo inside the poles to limit the bend, it didn't go to plan.
The bamboo went in fine but as soon as i put it back together my swr went up to 1.5 on channels 1 and 40. I can't get it back down to 1.1
I've taken the bamboo back out but can't get it back to its original swr, i have lost one of the pen marks on one of the poles, does anyone know the total length i should be aiming for?
Signal strength good though, picking up a lot of breakers from quite the distance.
Another factor may be the weather? It was sunny when i put it up originally but when i was doing the bamboo thing the weather changed, got very heavy and a bit rainy. Would this make a difference?
Mike
Posted: Wed Jun 29, 2022 10:04 pm
Hi Mike,
The total length should be 5.65m, so try setting it to that.
The rain may have had an effect on the SWR, I have seen that before.
Andy.
Posted: Mon Jul 04, 2022 7:26 pm
by Revomikey
Well after a couple of nights chasing the swr i decided the 2 week old swr meter from Amazon was faulty. Picked up a crt one from eBay instead, identical in its buttons.
That was it, as soon as i plugged it it the swr was 1.1 through all channels. Bamboo now inside the antenna and it's working great.
As with everything though there's a problem, the new crt swr meter doesn't work on pwr, never mind, it's the swr that's important.
From now on I'm only buying from the thunderpole website.
Posted: Tue Jul 05, 2022 1:40 pm
