COAXIAL CABLE splicing ❋
Posted: Thu Jun 04, 2026 10:01 pm
by Smithdoor
It is best to have one piece no splicing.
Most of today’s coaxial cable is plated copper on steel or aluminum. The shielding on most is aluminum.
Cheapest the Television F type good for RG 58 , RG59 and RG6.
BNC Easy to use and fast to disconnect too upto 29 watts.
239 type harder to use , more costly and takes time to disconnect over 50 watts depending on the chart.
⸻⸻⸻⸻ tapping ⸻⸻⸻⸻
1) before connecting use Qtip and apply a very small amount of ANTI OXIDANT COMPOUND note some can give a electrical/resistance so keep to small aerial. On aluminum wire you use a lot but not on radio/antenna connections. .
2) Make the connection tie.
3) Apply silicon on out side let setup. Electric wiring has liquid for this.
4) Rap withe Rubber splicing tape used for electric wiping 3 or 4 layers
5) Last is electric vinyl tape 3 or 4 layers. Do not use a cheap tape.
⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜⁜ This has work great for me when did not have option It is alway best to use one piece of wire no splicing.
Dave
