Yaesu FT 780 R Antenna
Posted: Thu Sep 03, 2026 3:12 pm
by Spinacle
I recently found a Yaesu FT 780 R clearing out a relatives house. It powers up and has a mic, but an antenna was no-where to be found. I have done a google and the prices of some antennas are expensive, and I'm not really sure what is what. As I am just getting back into the hobby and as money is quite tight, can anyone recommend a not so expensive antenna for my truck? Nothing long range? Something that will work in areas close to me to start with if it is cheaper?
Thanks,
Paul
Re: Yaesu FT 780 R Antenna
Posted: Tue Sep 08, 2026 5:40 pm
by Hair Bear
From reading your other post, the radio you have isn't a CB on 27mHz. Hopefully someone will confirm but I believe it's a ham type radio (licence required) at 430 - 440 mHz.
If you were wanting to get back into CB, a rig-mount-antenna kit would be £100 ish to get you started.
