Weak transmit signal
hayabusaman0
Hi All, My set has worked perfectly for the last 2 yrs with a good range, however the other day I got in the truck & found that the ariel was missing, I replaced it with a new one & since then have only 4-5 bars signal strength on transmit( most of the time 0 bars and can't transmit) and a weak reception. I have swopped mikes for a known good one & fitted my old ariel but it's still the same, I have moved the ariel connector around while pressing the transmit button & that makes no difference either, anyone got an idea of my problem please?
P.S. I can be heard, but only when another radio is very closeby.
Cheers, Hayabusaman.
swr meter on it as first step and we will take it from there
:D :D :D :D :D *King* *King*
fatfinger
Official CB Legend!!!
yes as stampman says swr is a must
sounds like you need to swr that antenna
Nugsport
CB Handle: Nugsport/Steve Alli-monster
Did you by any chance key the mic on the radio without the antenna conected, before you noticed the antenna was missing.?
Steve
DX The World
"Check Your Band Plan"
Homebase - Magnum S-9 Nitro Export > Sirio 827
Mobile - Midland Alan 78 Plus Multi > Sirio Megwatt 4000
26 PW 353
fatfinger
good point could have blown the set
could try a dummy load
Nugsport
Just what i was thinking matey the Output Transsistor could have gone. hopefully not for his sake. but you never know!
Steve
DX The World
26 PW 353
hi there is the coax damaged or been trapped in the door ...how old is radio and coax.it might just be what the guys say the outputs have gone :x
we will find out when the swr goes on
munky
I seem to be suffering a similar problem.
Just trying to get hold of a SWR meter tho, what should the reading be?
about 1.5 on 19 and below 2 on 1 and 40
munky
OK, so i've got myself a SWR meter, hooked it all up but the needle didnt move, not at all!
Is there anything I'm perhaps not doing?
if you followd the instructions on the swr meter then it looks like the set needs tender loveing care with a five pound hammer by a good rig doctor keep yor fingers crossed and it might only be a 2 pound hammer
:D :D :D :D :D *King* *King* *King*
munky
Ha! if only!
Its a brand new set!!!
I went out and got one last week!
take it back then and see what they say
