ground plane
bassy 1019
hi i want to use my sirio4000 in the garden, dont want it fixed, if i buy a groundplane to put it on would this work? or how to make one, put it on biscuit tin high swr.
matt
bassy 1019
hi stampman can you point me in the right direction
matt
our sponsers do a ground plane made out of aliminium in the shope of a cross with a hole in the middle for a mount the legs of the cross will support the antenna or are you mounting it on a pole if so its a differant kettle of fish
bassy 1019
magmounts dont stick to ally, so need some other form of metal
matt
I've used to run a tornado stinger magmount on an old car wheel rim which i earthed and got a pretty good SWR of 1 - 1.5.
best thing i've ever found is a sheet of 8x6 5mm thick steel off cut from a steel fabricators (had holes drilled in the wrong places so it was going cheap as an offcut.... £20!) which i winched up onto the garage roof (HEAVY!!!) and earthed it up to a grounding rod and the swr meter doesnt even move hardly.
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
