amature/cb radio set
marsh phantom
CB Handle: Marsh Phantom
the main unit is mounted under the glove box as my feed from the battery is there, then i have two permanent patch leads running into the back of the glove box where the swr meter sits. i have used velcro on the swr meter and filter box on the power lead of the radio so i can take them in and out with ease and they dont slide around, i have a yaesu extension speaker mounted in the drivers side foot well.
the head unit is up on the dash in front of the mpg/time screen
NOT MY CAR JUST A GENERIC PIC OFF THE NET
if you look above the screen in the center you will see a screen that says brakelight check...........that is where my head unit is mounted, there is just enough room down the side so i can still see what the display says on the car as the sticky thing that hold the headunit is stuck to the bottom of the overhang on the dash.
i will post pictures when i get my camera, should be in a week or so
it does look pretty neat now, plus i have routed all cables so they are hidden
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
FISH
Ed which yaesu ex-speaker are you useing in the car bud.iv drilled the holes t+k s are up 2x20ft poles are up swivels in place going to put antenna up tomorow if not raining, skip still a bit low so going to put imax up and not the beam. [-o< [-o< [-o< [-o< .
26 TANGO MIKE 501
marsh phantom
i use a yaesu mls-200 ex speaker, it works a treat, super loud and very good quality.
yer go for the imax until skip starts coming in, then you know its time to get the directional pigeon cooker going lol
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
killer cam
CB Handle: killer cam
:D
FISH
Seen the ex-speaker a lot of punch for a small speaker 12w,hows the 706 doing.can start to hear it coming in on 7mhz and 14 mhz but still 555 very low,are you picking any think up down south bud.
26 TANGO MIKE 501
marsh phantom
yer its pretty good.
im just toyin with some antenna ideas at the mo so not using the icom unless im in the car, hopefully by the end of next week i will have had some results .
aparently there was a bit of skip coming in the other day but i was not on the band to hear it
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
killer cam
I
FISH
Got the imax up a bit bottom of antenna at gutter hight,tried it on 555 radio sounds good,talked to one of the lads lives just over a 1 mile away used about 1watt output/ sig about 9db.not to bad and he users a beam.
26 TANGO MIKE 501
marsh phantom
good good, glad its up and working mate
hope to hear you on the band at some point
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
killer cam
do you think i should get an i max
FISH
How bigs your garden.
26 TANGO MIKE 501
FISH wrote:Got the imax up a bit bottom of antenna at gutter hight,tried it on 555 radio sounds good,talked to one of the lads lives just over a 1 mile away used about 1watt output/ sig about 9db.not to bad and he users a beam.
good job i bet it took some lifting have you any potos lol *King*
FISH
No pics yet going to try to get it up a bit more first.one thing i dont like about the imax is its 24ft long and a bit of wind and its all over the place,if i get some time going to spend it on 555 on monday morning,if its no good at least its elements are long enough for sun flowers.and stick the 4 element beam up.
26 TANGO MIKE 501
oh no give it a chance andy or give it to me lol but you are right they are very long and heavy to lift .. #-o :D
FISH
I can see me going to use the beam more now,just a bit sick was going to import a maco 6 element beam from usa but now with the pound so low its going to cost to much so thats on a back burner for now.but i will still give the imax a try.
26 TANGO MIKE 501
