so realy looking forward to it becos the skip is going realy well too
dx weekend may
oldskooldaze
Probably will try Sunday / Monday , managed to get 100km south of Berlin today not bad on a Wilson 1000
Slowly getting there =D>
- marsh phantom
- CB Handle: Marsh Phantom
will be on no doubt
listen out for
26-TM-1986
listen out for
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
Marshphantom
26-TM-1986
Scanner Yaesu VR500
Should be on UK40 on Saturday - generally listening on 19, but putting a few shouts out on Ch25 (good coverage of Wales from that QTH). On Sunday and Monday on SSB, and if Germany starts coming in like last Sunday, I'll give the EU block a try using FM.
If the skip really kicks-off, I'll put the 7ft Firestick on the van and head for a hill.
Cheers.
Gary
26-TM-2307
Cheers.
Gary
26-TM-2307
- marsh phantom
same here nothing today apart from the local guys
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
Marshphantom
26-TM-1986
Scanner Yaesu VR500
- porky.69
- - - -> CB God <- - -
oh gary im gutted ..i shouted you but the guy next door has a plasmar tv wich gives me 30 db of qrm ...im going out tomorow on 555 i hope to cach youOffplanet wrote:Porky - another half a 'S' point and I'll be able to copy you no problem![]()
What's giving you the QRM mate?
Good to catch TM 71 this time.
Gary
26-TM-2307
soon
- marsh phantom
i also spoke to tm71 up in them clee hills (i went past there the other day), was using my spinger setup in the flat as im on duty so no hills for me
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
Marshphantom
26-TM-1986
Scanner Yaesu VR500
Shame about the TV - I've had the same sort of problems and it's usually to do with the switched-mode power supplies in the modern kit.
Even this week I found my broadband router was giving S7 on some channels, and I cured this by using a universal regulated power supply from a local electronics shop instead of the one supplied with the unit.
I've got the QRM down on a lot of items using ferrites - the ring ones seem to work better than the clip on ones. I still get some with the DX setup in Bath, but no more than half a S point at the home QTH.
Hope the guy next door will let you try a few things!
I'm unlikely to be on SSB tomorrow, as I'll probably be at the Home QTH with only the UK40 at my disposal - there's always next time though.
I was putting a decent signal up to TM 71, but the trouble was that nobody else could hear each other
Cheers.
Cheers.
- marsh phantom
you signal is flying straight over my twig gary, hereford is in a slight bowl though so that dont help, i was even giving a cracking signal to tm71 today.Offplanet wrote:
I was putting a decent signal up to TM 71, but the trouble was that nobody else could hear each other![]()
Cheers.
he even said he could fault the lincolns audio, its doing me proud i tell you
Ed
Marshphantom
26-TM-1986
Scanner Yaesu VR500
Marshphantom
26-TM-1986
Scanner Yaesu VR500
Clee Hills do seem to be a particularly good spot.
Good to hear the Lincoln is doing the biz.
Tony TM-034 said my Stalker is bang-on frequency, so it looks like my pen marks around the dial are spot-on (who needs a frequency counter
