fed up and need help dv27
Are you sure your SWR Meter isn't duff?padster wrote:well i got my pl259 got a aparks to connect it a mate set my new dv 27 up on tin lid and cant get swr down i do not know what to do had my rig since last tues not used it yet![]()
Steve ("Cherokee")
Not sure what difference it would make but we always used the tin base and not the lid
BEER IS FOR LIFE,NOT JUST FOR CHRISTMAS!
26-TM-1969 - Red Squirrel - Spinney Hill - mpcapri - more aliases than what's his name
Also double check the pl295 connections, make sure the solder has not become loose (it happened to me once)
http://www.thunderpole.co.uk/forum/view ... f=18&t=748 connect a pl295 plug
- padster
- Chatter Box
- CB Handle: night owl
i sussed it used base and put foil down on floor readings now channel 1 1.4 channel 20 1.3 and channel 40 2.4 is this ok and safe to transmitdisgwylfa wrote:Are you sure your SWR Meter isn't duff?padster wrote:well i got my pl259 got a aparks to connect it a mate set my new dv 27 up on tin lid and cant get swr down i do not know what to do had my rig since last tues not used it yet![]()
Steve ("Cherokee")
I've replied to this same question on one of the other threads, but what the heck...padster wrote: i sussed it used base and put foil down on floor readings now channel 1 1.4 channel 20 1.3 and channel 40 2.4 is this ok and safe to transmit
The 2.4 is a bit borderline. Generally it's considered that "anything under three" won't cook your Finals but as your SWR is higher on the top-end I would adjust that DV27 slightly. Lower the adjustable tip by about 2mm and check the SWR again. Then maybe lower it another 2mm. A DV27 really should get you under 2.0 on all 40 channels.
Steve ("Cherokee")
- padster
- Chatter Box
i got channel 1 1.6 cahannel 20 0.1and channel 40 1.7 is this okdisgwylfa wrote:I've replied to this same question on one of the other threads, but what the heck...padster wrote: i sussed it used base and put foil down on floor readings now channel 1 1.4 channel 20 1.3 and channel 40 2.4 is this ok and safe to transmit
Steve ("Cherokee")
- killer cam
- - - -> CB God <- - -
- CB Handle: killer cam
thats fine
