Pig_Pen wrote:
We need radios that we can use in France as well as the UK.
We don't need much in the way of range.
We do need easy to use with clear sound - can you use an earpiece?
We don't want HUGE yellow fishing rod aerials, in fact the smaller the better.
Do we need to SWR the units you sell as a starter pack, or will they be close enough?
Ohhh and we don't want to spend a fortune
#1: Any CB radio that can use the 40 EU channels: I believe that Thunderpole doesn't sell any that don't have these channels anymore.
#2: Well, make sure to get a LITTLE range. Although all CB radios have the same range, it's all in the aerial.
#3: Most CB radios are clear at close range: however, the midland 38 (I think) or 98 are nice clear radios. I like midlands. However, the only radios I am aware of that can use an earpiece are handhelds: which tend to be expensive (and less reliable!)
#4: You can get an aerial that's only about one and a half to two feet high: mounted on a magmount on your car, that should be perfect for range.
#5: I don't personally believe in SWR meters as a necessity... I wouldn't bother... they do however detect faults! My advice is not to bother though, or pick up a really old one off Ebay if you do. They are rarely broken and mine cost about three quid with postage
#6: If you want something new, I would stay here, if you know what you're doing, go to ebay: but I find newer CB radios on Ebay are an absolute pitfall, and very difficult to buy. I recommend Midland 38 or 98 from here personally...
*By the way, can I point out that I'm no expert, just a keen amatuer?
