interference
is fuel pump mounted in rubber and isoated from chassis if so try earthing strap and condenser across power feed in fact disconect power supply to pump and see if that cures it for a start
Have you got a good earth on the braid side of the coax? If you have a multimeter, unplug the coax and check from the outside of the plug to a handy earth (I usually use the door catch). Also check for continuity between the centre pin and the antenna (I am guessing you have that otherwise your SWR would be off the scale).
I have spent since before Christmas helping a mate with a Disco sort out his CB. His was mounted on a Safari roof rack. Apart from having the coax full of water from using a snail mount on the ali chequer plate he has lined the roof rack with, the roof rack wasn't earthed to the truck because of the plastic gutter trim.
I refitted the antenna using a 3/8" stud mount, after grinding the chequer pattern off one square of the chequer plate and earthed the roof rack to the truck via one of the spotlight grounds. It is now working well.
If you dont have a multimeter a 1.5V battery and a 1.5 volt torch bulb will do for checking.
BTW, I get bad interference from the turbo on my Surf. At least the noise only comes up when the turbo kicks in, which is most of the time.
