Ferrite Rings
stewartyboy01824
Hi there, Was wondering about your knoledge on ferrite rings, do they work? What are the best type to buy? And where to use them?
As i mentioned in my last post i have a major interference problem with the cb in my tractor. You guys are mentioning ferrite rings which i will certainly have to try as im losing pacience, lol.
I have seen them on the net now, do you think the clamp ones would be sufficient rather than the ring type?? They would certainly be alot easier.
Evil planet mentioned putting them on my fuel injectors only today i found there pretty much inaccessable along with the fact theres wires and cables everywhere going in and out of the fuel pump.
Having spoken to my local cb shop today he says put them on your aerial coax and maybe the thick power cable coming from the battery into the cab to surpress any noise.
Do you think either of these places would have the same effect and be sufficient enough?? And do you think i could use more than one, on the coax cable for instance?? Maybe two would double my chances?
Many thanks again for all your advice and comments!!
Phil_G
as far as I know of ferrite coils, they are also used in my industry to shield the sensor wires for chemical dosing systems from electromagnetic interference, so I'd say that they do indeed work. The problem is in your case pinning down where the interference is getting into your system.
Phil
stewartyboy01824
Thanks phil!
