Hi there. Me and my mates at Manchester Minis are a bit amatuerish at this CB malarky! Can anyone answer some probably obvious questions?
First things first:
I can't get my SWR below 1.7 on channel 20, its about 1.4 on 1 and about 1.9 on 40. Am I right in thinking that the antenna needs to be a bit shorter? Its as low as it will go at the moment. Can I shave a little bit off it?
My setup is a Midland 38, 7" magmount and a 5ft Stinger on a 1994 Rover Mini.
Unusually though everyone says my rig is great, can pick it up miles away dead clear and I usually hear others coming before my mates can.
I'd also really like one of those echo/power mics with the sound effects and a roger bleep!! No where seems to sell them anymore though. Des anyone know where I can get one from?
I'm sorting out a mate's Mini Van on thursday with a spare rig I have been given. It seems really retro. Original 27/81 standard, its got Manor Kestrel wrote on it. Seems to work ok and even has a swtich to turn the roger bleep on or off. Does anyone know much about these rigs?
Edd.
A few quick questions
- andy@thunderpole.co.uk
- Site Admin
- Contact:
Hi Edd,
I wouldn't worry too much about those readings, especially as your setup is working well, but yes shortening it should lower the SWR across the band. Its best to take off very small amounts at a time though, maybe 5-10mm as you can't put it back on
We use bolt croppers here, the whips are stainless steel and are pretty tough to cut with anything else (be careful with your eyes if you do it though, the bits of whip can ping off at some speed!)
Echo mics here... http://www.thunderpole.co.uk/microphones-e-p-n.htm
From memory the Manor Kestrel was the same as a Planet 2000, were good at the time but must be at least 25 years old now!
The Roadie
Thanks very much for the help!
Does that K-PO mic have sound effects though?
- Bionic Budgie
- Motor Mouth!
- CB Handle: Bionic Budgie
the Kpo echo mic is just that.. echo with adjustable mic volume (power mic). If you want a roger bleep, the best way is to install a bleep board inside the radio, this is really easy if you're ok with an iron. Remember to make it switchable though. The most popular way is to use a switch on the radio that you don't use like PA, if not, a small toggle switch mounted on the rear is good. Just a personal note, if you do go down the echo/bleep road, keep the echo at a sensible level. Here in Norfolk, we have a num-nuts who has the delay flat out and he sounds shite! Because he won't turn it downand is so difficult to understand, folks won't talk to him..I think he's eaten too many turnips. If your a complete loony...every now and then, you can find a mic called an F10 (or something like that) this has all the Dilek, echo, alien stuff on....if you want to get one of those..please ask permission off the person who has the key to your straight jacket first, failing that..go and see Mr Bridger.The Roadie wrote:Thanks very much for the help!
Last but not least...'Your Only Meant To Blow The Bloody Doors Off...'
Cheers N Beers
Ian
Bionic Budgie
Diss 20
