I've been toying with the idea of going for the Foundation Licence, but have a few questions about equipment...
I know with the foundation licence I'd be limited to 10W, but most units seem to offer more like 50W and up, is there a way of turning down the power on these units?
Then theres the question of wavelengths. 70cm, 2m, 6m, 10m etc, which wavelengths would I actually be able to use with the Foundation license? and which bands is it recommended for getting started in Amateur Radio with (basically what kind of radio to buy first)?
Finally I presume a mobile setup is pretty much the same as for a CB?
Also are SWR meters universal, or do you need a different one for each band?
Lot of questions I know, but thats it for now. And I know one answer will probably be to join a club, but my local club: Ipswich last updated their website in 2004 and had one meeting a month then. Any club that hasn't made an update to their website in 7 years, doesn't bode well for running the tuition I'd need to pass the foundation.
Curious noob, with questions about Amateur Radio
yes they will turn down on the set
you can use all wave lengths
you can sart any where try local radiop club for info
mobile set ups same as cb
zatagi mod 203 for swr meter our sponsers do them
radio hams move slowley byt surley the probable lost the computer expert so they cant up date the site go and chat you could fill that post
checkpointcharlie
Yea go for the licence i like all aspects of Radio HAM/CB im not a purist and love my CB infact £2000 in 2 Ham Radios and they are not even switched on at the minute unlike my spanking new KPO DX5000 which is singing away in the back ground
10/4 73s
I want a hygain penertrator or mighty magnum what happened to the legends?
Just got the Foundation Licence NOW! book, to be honest nothing seems that special or technical, other than having to learn morse.
Exactly why you have to learn a code that was abandoned in any practical form a few years back is a mystery, but if thats a requirement, then I'll have to look for a tutorial package.
checkpointcharlie
You dont have to learn morse i think they get you in to send a few words that you read from a board easy stuff get forward mate,
Regards Mark alias Checkpoint Charlie 10/4
Think it's a one time deal, for the licence. But you're limited in terms of power (10w), and you can't modify your radio transmitter while you're only on the foundation.
But if you look at the equipment, CB runs on 11 meter, and one of the more common frequencies is 10m, which means many tweaked CB's antennas will run into this band, and certain tweaked CB's can operate 10m. So effectively getting the foundation, and operating one of the ham bands can be really cheap.
Beggin yer pardon, but that's not actually correct. A Foundation Licence holder can use the HF Amateur Band, 6m ,VHF (2m) and UHF (70cm), but is not allowed to use the the higher frequencies such as 23cm / Microwave etc.stampman wrote: you can use all wave lengths
the Zetagi HP203 will NOT do UHF. So if you have a set capable of 70cms, that particular Meter is no good for you. There are plenty out there that WILL cover 1.8MHz to 525MHz such as the K-Po SX-40 from Thunderpole - LINKstampman wrote:zatagi mod 203 for swr meter our sponsers do them
Foundation can use Microwaves, the bands they have are:MikeZero wrote:Beggin yer pardon, but that's not actually correct. A Foundation Licence holder can use the HF Amateur Band, 6m ,VHF (2m) and UHF (70cm), but is not allowed to use the the higher frequencies such as 23cm / Microwave etc.
136 kHz, 1.8, 3.5, 7, 10 14, 18, 21, 24, 28, 50, 70,144, 430 MHz plus the 10 GHz Microwave band
Trevor
http://www.g0mwt.org.uk/training/
