...and for my next (ignorant) antenna Q...
AdvancedRoadcraft
CB Handle: Golf Zulu
...OK, the mobile CB antenna is up, fixed & working great.
But I now want to run a separate scanner (to be used for CB channels only) in the car. Can I just use a "splitter" at the CB end of the antenna cable and run a short length from the "splitter" to each of the two units, or would I be better off installing a dedicated antenna specially for the scanner?
And, if the latter, any recommendations would be gratefully received.
Thanks in advance, chaps, B
Best, B
(Barry = "Gulf Zulu")
needle bender
Hi,you say you want a scanner just to monitor cb channels???...well why not use a cb transceiver with scan capability...or are you looking to scan a more comprehensive range of cb frequencies...freeband etc??? :D
Andy Nazel
Hello! :D If you just use a "splitter" then the 4watts from your cb will go straight into your scanners aerial hole when you key up and kill its recieve circuit!! :cry: Best to use a separate aerial.Check out Thunderpoles range to see which one is best for you but I've used a Skyscan Mobile and had no problems the only thing is the" multi- antannae" arrangement does draw attention.Was once asked"Are you TV Licensing" :D
AdvancedRoadcraft
needle bender wrote:Hi,you say you want a scanner just to monitor cb channels???...well why not use a cb transceiver with scan capability...or are you looking to scan a more comprehensive range of cb frequencies...freeband etc??? :D
Because I've got a (non-scanning) CB unit that I'm happy with and don't therefore want to swap just to get one extra feature!
Best, B
Best, B
AdvancedRoadcraft
Andy Nazel wrote:Hello! :D If you just use a "splitter" then the 4watts from your cb will go straight into your scanners aerial hole when you key up and kill its recieve circuit!! :cry: Best to use a separate aerial.Check out Thunderpoles range to see which one is best for you but I've used a Skyscan Mobile and had no problems the only thing is the" multi- antannae" arrangement does draw attention.Was once asked"Are you TV Licensing" :D
That was a circuit description that even I could understand!
Many thanks for saving me an expensive mistake; I'll do as you suggest.
Best, B
Best, B
if you ring Colin at our sponsors they do a splitter that you can use it taps the signal from the cb antenna to your scanner without aloowing the tx power to download into your scanner
