loft antenna
needle bender
How well would a siver rod type antenna work slung horizonal in a loft space...any of you antenna buffs got any idea???
- Adriano9966
- Official CB Nut
The feedpoint is a simple chop block which can be screwed under the roof apex but don't forget to solder the braid and the centre core so that they are 'tinned' and will give a good connection
http://www.transmission1.co.uk/forum/vi ... 4&start=15
- Adriano9966
- Official CB Nut
needle bender
well,bin helping an old breaker back on cb radio after 20 years...local council regs dont permit him to have a large antenna..so after trying several mobile antenna's in his loft have settled on a half wave silver rod mounted horizontal...the good news is it works very well...he was happy to be able to copy a breaker about about 15 miles distant last night,,good signal and mod report...gonna spend the day with him sunday and see just what its capable of...thanks for info on inverted v adriano...might give it a shot sometime...have made antenna's in the past with varying results none that i can conclude being better than the usual commericial types.still all good fun trying..
