car CB/ base station?
generic_eric
i prosume people have done this already but what is the easiest way to set up a vehicle CB as a base station in my home?
i am thinking of getting a CB starter kit after xmas and would ideally like a piece of equipment that i can use both in my vehicle and also take it out and use it in my home at night.
i own a handheld CB at the moment but i from what ive read on here, i dont thing think its work spending money on and i might as well start new/ ish.
this is my handheld.
http://www.radiopics.com/CB_Radio/UK%20 ... timate.htm
if anyone knows who i can turn this into an effective base statio i would appreciate it.
Eric
Hi Eric,
Firstly you will need a 12v power supply unit(unless you want to run it on batteries)... http://www.thunderpole.co.uk/power-supplies.html
Then obviously a base station antenna... http://www.thunderpole.co.uk/base-cb-antennas.html And fittings to put it up... http://www.thunderpole.co.uk/homebase-fittings.html
And then all you will need is a cable to connect it to the radio... http://www.thunderpole.co.uk/leads.html
From memory the antenna is a screw-on type for that radio (TNC) so you may also need an adaptor for that to attach the antenna cable.
hi eric what sort of things do you want out of radio *King*
generic_eric
cheers for your help guys.
there is a lot to learn.
im terms of what i want my CB for. the simple answer is to keep in contact with people. i have friends abotu 6 miles from me who use cb they use it in their tractors and 4x4's. i bought a hand held to see if i could pick up there signal but the only tiem i recieve a signal is when im in birmingham. i am prosuming that my handheld is not up to the job.
i am plannign on getting my amature license inthe new year and i thought this would be a great way for me too learn about RF's.
i have a caravan at the bottom of my field which is at least 200 yeards from any home which i plan to turn into my radio shack next year. this means i am going to have to power all my devices using a lesuire battery so any advice on the matter would be appreciated.
btw - is anyone based in or around suffolk?
Eric.
i would have a look at a good 80 channel cb radio and a simple silver rod antenna for base use
the antenna is the most important thing, i use a antron 99 and that is a very good antenna *King*
hi eric & welcome,
with your already owning a handheld radio the only things you will really need is a adapter as you are able to unscrew your rubber duck antenna off to put the adapter on to fit a mobile or a home base antennna http://www.thunderpole.co.uk/large-cb-antennas.html & a mag mount for your mobile antenna http://www.thunderpole.co.uk/magnetic-m ... large.html for when your out & about in the car & also a home base antenna for when your at home, the only thing you will need for your radio what you have now is to make sure you have 8 AA battery's charged to get the full 4 wats & a charger should have come with your handheld to charge them with,
collecting cb equipment for the first time might not seem to be cheap but sure is worth it after you have bought everything you need
& after Christmas when you have enough money to buy a proper mobile & a home base set up thunderpole always has a good collection of radios for sale & starter kits http://www.thunderpole.co.uk/cb-radio-packs.html
