For all of you this should be a very basic request for help!
I am not (currently) a CB user, but my local church is now transmitting services on CB. The supplied £15 receiver is, not suprisingly, of poor quality and given the location of the house, reception is not good.
Is there a receiver out there which is competitively priced, mains powered and ideally have a reomote control?
Have I given sufficient detail?
Many thanks.
John.
Basic CB receiver
- andy@thunderpole.co.uk
- Site Admin
- Contact:
Hi John,
The only 'receive only' CB radio we do is the Intek CBM450...
http://www.thunderpole.co.uk/mobile-cbs ... 0-kit.html
It is 12v powered so would require a 12v mains power supply, but it won't draw much power at all so that shouldn't cost you much.
I would say it should work a lot better than the £15 receiver you have already.
From hearing the CADS broadcasts myself they don't always seem to be broadcasting on a recognised CB channel, many times I hear them for example on say 27.442 mhz not always ending in 0 or 5.@ JohnGOF, are you in England or Ireland?.....perhaps you don't hear the broadcasts that well because the receiver you are using is not on the exact same frequency as the broadcast?......just a thought and observation
ANDY could supply you with a cheap cb radio with a plug to put in the mic socket to just receive the signals or even disconnect the transmit signal so it would only receive and that would sort your problem out
Hi Folks,
I've had a look at the CMB450 and it looks like a good option from performance and price. This receiver is not for me - it is for an elderly relative - hence the request for remote operation.
I like the idea of disabling the transmit functions to widen the selection.
Situation is in Ireland, County Derry.
Thanks.
Thanks.
- Site Admin
- Contact:
