Radios - which way to turn ?
salop sniper
This may sound a simple question but i doubt the answer will be..........
I want to get on the airwaves chatting away etc. So far i have a Relistic Pro-62 scanner and a pair of PMR446: Cobra MT725 PMR446 Radios.
I also own a Suzuki Jimny 4x4 and am out in the country alot shooting and regulary travell on the A41, M54, A442 in the shropshire area which are all well used by 4x4 owners farmers and truckers so i would hope there would be others out there on the airwaves some where.
So what can i do with the kit ive got and secondly if i had a budget of £100 for CB what kit would you advise and what could i expect from it.
I suspect the answer to it all is that the: 446, scanner and cb would all be dead as a door nail and I would have spent money on good kit only to still be unable to make any regular contact .
Whats your thoughts and advice on this ?
Regards
Matt
446 is only short range cb radio an intek works fine the kpo k500 has a scan button on it and the best antenna you can afford remembering its the antenna that does the job
salop sniper
But is it really worth investing the money into CB ?
The only regular users of radio in vehicles these days seems to be HM users and Raynet :(
ATB
Matt
Unfortunately you will have to try a CB set up to find out if there are regular users in your area so buy a cheep set up first , Orbiter antenna is cheep and robust , Ideal for off roading - http://www.thunderpole.co.uk/large-cb-a ... bitor.html
And 6ins magnet mount http://www.thunderpole.co.uk/magnetic-m ... large.html
TTI TCB-660 gets good reports and is expandable for lots of frequencys http://www.thunderpole.co.uk/mobile-cbs ... b-660.html
theres plenty of people on the cb radio in salop *King*
salop sniper
Are you a fellow salopian porky ? And are you on CB ?
Regards
Matt
salop sniper wrote:Are you a fellow salopian porky ? And are you on CB ?
Regards
Matt
hi matt have you got a set up yet mate *King*
hi salop sniper,
the only advice i can give for anybody wanting to be heard while mobile is the sirio hi-power 3000 or if you wanted the hi-power 4000 why would these be my choice well the simple solution is what they are 7/8 wave antennas & will need Any SO-239 mount,
but for static mobile i would suggest a 6" large or a 7" turbo mag mount or you could go for a hatchback or a boot mount with a tank whip but what ever you choose good luck buddy :wink:
