bit thick here
A place for homebase users to chat when they're not on the air
randombod
CB Handle: randombod
I am new to the home base cb scene i was wondering what i need to get one up i have an old union cb a power supply from thunderpole i think will power it and a small mag mount i take it the antenna needs upgrading but what about the rest. The one in the car is now champion (cheers andy and crew) but i have always wanted a home base one but her in doors has my bank card...... so whats missing from the list / needed?
cheers guys
just a home base antenna it would seem
randombod
shame i cant use a big mag mount clagged on the o/s as a temp measure
mag mount on a fridge or cooker or any large metal object will do if swr is reasonable suppliers do a ground plane system you could fit in loft
randombod
excelent ill have to have a bash at that some time see what the out come is
no problem good luck
triple loaded thunderstick in the attic on a biscuit tin would work well i would guess :lol:
AppleTree
CB Handle: Uncle Bulgaria
I had a mag mount with a spring whip in my loft and it didn't work... The SWR was always sky high and wouldn't go down...
It worked better stuck on my radiator on the ground floor!
Or 145.500 FM 8-)
A 18ft GP works well in the loft though a bit directional . 8ft 3in either side Wire dipole works quite good in the loft .
AppleTree
Might as well just stick an antenna outside lol
Or 145.500 FM 8-)
