Help With Old Rig Diag Please
Amige-Tinout
CB Handle: Road Runner
It's Life Jim, But Not As We Know It... I recently found a rather old CB radio my father purchased for me many years ago as a boy and I would love to get it working again and even restore it as a project perhaps.
I have had it connected to a mobile antenna to see if I could get any Rx to start with, but all I managed was some signal; both back in the box and some stronger signals as well, but no voice. I wonder is someone more knowledgeable than me on this could point me in a sensible direction of investigation as to what this may be.
Regards & Thanks,
Road Runner (Bournemouth)
i dont think you will pick many stations up with a in door antenna. for the best results you need a outdoor antenna like a a99 or a silver rod :D
What radio is it ,
It may be an old AM set in which case you may hear the USA superbowl on channel 6 Mid , AM will be legal to use in the UK in June or july so 19 AM may get a lot more use then , If it is a UK FM radio then 19 is the channel to call for a radio check , Indoor magnetic antennas usually work best stuck to a radiator or a fridge or washing machine .
Amige-Tinout
Hi, thanks for the replies.
I had tried a large sheet of steel on a roof as a ground plane, with a base loaded mobile antenna stuck on it, just as that's what Maplins had on the shelf shortly after I re-discovered the CB radio in the loft and grabbed the car keys with a grin... I got signal on the 19 and some stronger on other channels, but without any voice however, which made me scratch my head a bit and wonder if I should see if it rattles... (I.E. did the loft brake my rig?)
The CB is an old Ham International Jumbo that had the UK 40 as well (CB 27/81), plus mid of course, or low as it says on the rig's dial. I plan to obtain and plug in a frequency counter (port on rear on CB), so I know for sure I'm on appropriate frequencies, pre Tx. It will be hopefully OK on AM & SSB, which can be tested as and when we see that come in here in the UK; soon by the looks of things. In the meanwhile, I just want to get Rx working on FM, so I have taken the mobile antenna back and am looking in to a 5/8 wave to stick on a scaffold pole.
I love technology and finding this old rig has been amusing, even though I Haven't really got anything out of it, researching and learning is fun to start on a new topic. I am a qualified IT engineer, so hopefully I can transfer some skills and enjoy playing with rigs and antenna whilst developing a grey moustache and beard (few years yet).
PS, the SWR on the mobile antenna was 1.2 right away, but I'm sure the base antenna will involve adjustment to length to perfect the SWR; part of the fun (remind me I said that).
Regards,
Amigetinout / Roadrunner
Asterix
Is that right, A.M. legal soon in the uk ? bring it on :D
Asterix wrote:Is that right, A.M. legal soon in the uk ? bring it on :D
so they say....but it wont be has good now its all legal :D
Asterix
Damn :( would I be right in saying it would also be on a different frequency than the old a.m. to ?
clouseau
CB Handle: Clouseau
the AM channels that are now legal are between 26.965-27.405 which is the old American 40 channel band, otherwise known as 'mid band' or EU/CEPT in Europe. the same goes for SSB, sadly the channels in between the EU and the UK40 band which are popular with DX'ers have not been legalised, ruling out 27.555 for legal use.
bobthetank
Hello
not sure which version of Jumbo you have,need to look for PCB version on board.
Ther version 3 schematics have upgrades that you can do if yours is a version 2 by comparing.
You will also need some test gear to get radio aligned correctly and setup .
Freq counter-pref calibrated
Signal generator am\fm with built in dis\SINAD or can use seperates.
am\fm modulation meter
RF pass thru box-connect freq,mod meter up sniff rf
50ohm dummy load
Scope
3ohm 5 watt resistor for audi connection to ext speaker
50ohm dummy load 50w-100w rms rated.
Patch cables
Scope leads
A monitor radio with am,fm,ssb to check audio\on freq
I found some schematics that may help you.
http://www.radiomanual.info/schemi/CB/C ... o_user.pdf
http://www.cbradio.nl/ham/Service_Manua ... er_ENG.pdf
Good Luck :)
