Interference
Darren226
Hi having an issue with interference the rig is a tti 1100 it's ok on receive AM/FM and ok on transmit FM but on transmit AM all it transmits is noise the swr is 1:1 I've tried connecting to 4 different power sources and two different voltage droppers in my truck all to no avail ideas any one?
Multinorm radios will only allow AM to work on the german and polish bands , The TTI TCB1100 can be opened up to 25 to 30mhz AM FM by moving a resistor inside , The UK40 wont be there though in export mode so the radio will have to be switched off and restarted with a particular button pressed to switch between UK norms and Export mode each time you want to use AM on mid band .
Here is the mod for moving the resistor to enable Export Mode .
http://uk1ab.comlu.com/ukmods/ukmod002.html
alter it to the italian band E1 and it should work fine
Just checked on my multinorm handheld and AM FM works on the Italian band ,Learn something new every day , cheers Stampman
Darren226
Am works on whatever country code you choose except UK obviously,(although I suppose that will now change on new ones seeing as the law has changed) can receive but not transmit after a couple of phone calls in which both said same thing sounds like dry joint on the am transmitter circuit. Thanks for your help though guys.
