Linear amp cooling fans.....which type?
millsrocks
CB Handle: Suicide Jockey
Hi.
When using computer fans on top of Linear amps to cool them down, which type is best to use as not to cause any interference?
Ball Bearing, Sleeve, or hydraulic?
My home-base amp (EA-150p) has a 9cm x 9cm hydraulic fan on top of it pulling heat away. It doesn't seem to cause any noise electrically to my RX or TX, however i can't seem to find anymore at all online.
What would be the next best one to use? Ball or Sleeve bearing?
Cheers...
Richie.
"Suicide Jockey"
Leatherhead, Surrey, UK
Radios:
President Grant II (base)
President Lincoln II (mobile)
Antennas:
Sirio Gain-Master (base)
Sirio 3000 Hi-Power (mobile)
