just recently I have been able to receive but not reply
Old CB not wanting to play
Hello folks, I have only just dug my old CB out of the loft and actually remembered how much fun they were
BUT !!
. Bin told my mike is faulty but can't just replace it with any old 4 pin mike it has to be the same make as the rig ? This must be correct because I tried my mates 4 pin mike and it did not work.....Bugger. Even bigger Bugger is I dont know the make of my rig...Oh eck. Got model numbers on the back, can anyone give me a big shove in the right direction please, Thanks Sando63
Cheer's stampman, are these any good to ya
Serial No 873237, model DW 900FM, and finally MPT 1320uk, it's all Korean to me
Thanks for your reply.....PS, if you say pin No 3 and 4 need swapping over for example, which pin is which, or which is 3 and which is 4
I suppose it's easy when you know how, Regard, Sando63.
Dose it look like this - http://www.cbmuseum.nl/Engeland.htm
Post a pic of your mic as midland / Kernow have a variety of mics .
If it is the Kernow then it will most likely be wired the same as the Kernow 1100 and 5100 unless it has channel change on the mic but it looks 4 pin so so it probably wont have mic channell change ,
Loads of choice on the Thunderpoll shop - http://www.thunderpole.co.uk/cb-microphones.html
