I drive a fendt828 and have great reception
When the engine is off,as soon as I start up it
Goes pants. There are so much electrics and
For different equipment that I tow ,anyone
Have an answer?
Noise.
you ave to cure the interference at source line choke choke would rarely work as in general the interference is rf and picked up by the antenna first unscrew the antanna and see if the noise alters if so you have to then find out if its just when switched on or only comes on when the engine is running if so is it the alternator no an easy think to sort but can be done with time and patience
